CCME + CUE Service Module Failed
Feb 15th, 2007
Customer has a 2811 router with an NM-CUE module. Service-Module Service-Engine 1/0 status show the following:
Service Module is Cisco Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is waiting for registration message
Service Module status is not available
I have tried to open a session with the service module and it says the session is open, but I get no output it just sits there. I have tried resetting the service module from another telnet session while the session is connected but to no avail. Is there anything that I can do to fix this without replacing the module? Thanks in advance for any help.
Markus Schneider Thu, 02/15/2007 - 12:12
  • Cisco Employee,
That sounds pretty bad. Can you try to reset the card? The registration message is one of the first thing the card sends out if it's properly connected/functioning. You could do a 'debug scp packets' (maybe even 'deb scp all') on the router and reset the card and/or re-seat the card and see if you get anything. Otherwise it sounds like a faulty module.
hatfieldm Thu, 02/15/2007 - 21:53
I tried debug scp packets and I get opcode (0x11). The troubleshooting guide that I was reading didn't have that opcode listed.
gogasca Thu, 02/15/2007 - 23:20
  • Green, 3000 points or more
0x11 means SERVICE_MODULE_PING it is sent from Router to module in order to test basic connectivity...
hatfieldm Wed, 02/21/2007 - 08:40
The service module seems to respond to the shutdown command and now shows status of "is Shutdown". Is there anything to be gained by reseating the module?
marcfuhrmann Thu, 02/22/2007 - 06:41
hi,
I had the same problem here. I put the service module in shutdown and restartet the complete ISR 28xx. After that I was able to telnet the service module again.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddb080c
Marc
hatfieldm Thu, 02/22/2007 - 06:46
Thanks. I actually got Cisco TAC involved and they recommended the same thing. Unity Express is back up and working with no lost data. WoooHooo! Thanks again to all that helped.
