ASA SSM Module inspecting and blocking Internet Radio
I am implementing ASA's with SSM modules and I wanted confirmation that they can inspect http and block embedded traffic such as Internet Radio from being tunnelled through HTTP.
The Cisco documentation hints at this, but I would like confirmation.
We will be implementing WebSense, but I was hoping the SSM modules would be a good temporary solution.
Thanks in advance.
Andrew Ossipov Thu, 02/22/2007 - 20:48
Are you using AIP-SSM (Intrusion Prevention) or CSC-SSM (Content Security)?
Andrew
Andrew Ossipov Sat, 02/24/2007 - 22:55
The AIP-SSM module is not designed for content filtering. You should probably try CSC-SSM for that, but you can also use Modular Policy Framework (MPF) on the ASA itself to accomplish the task:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/conf_gd/firewall/mpc.htm
It's even simpler through ASDM, where you have some pre-defined maps that allow you to block streaming audio/video over HTTP.
Andrew
