NAT help with PIX 7.0(1)
brandon.hodge
Can you NAT an internal IP to the external interface IP? I'm used to doing this on sidewinders but it's giving me an overlap error
8 Replies 8
vitripat
Level 7
Level 7
Yes, you can translate whole of your internal network to the external interface IP. What is the error you are recieving?
Error: 204.34.211.97-204.34.211.97 overlaps with outside interface address
if you want to hide the internal network to
the External interface ip address of the
firewall, Linux called IP masquerading,
Checkpoint called it "hide" NAT and cisco
refers to it a Port Address Translation (PAT):
nat (inside) 1 0 0
global (outside) 1 interface
I just did
nat (inside) 1 192.168.1.10 255.255.255.255
the ip is still coming out with 192.168.1.10(example only) do the static(inside,outside) entries override the global?
If you have a one-to-one static for this IP address, it will take precedence over normal nat/global configuration. Here is the order of NAT operations-
1) nat 0 access-list (nat-exempt)
2) match against existing xlates
3) static
a) static nat with and without access-list (first match)
b) static pat with and without access-list (first match)
4) nat
a) nat access-list (first match)
Note: nat 0 access-list is not part of this command.
b) nat
(best match)
Note: When choosing a global address from multiple pools with
the same nat id, the following order is tried
i) if the id is 0, create an identity xlate.
ii) use the global pool for dynamic NAT
iii) use the global pool for dynamic PAT
5) Error
Hello!
Where can I find in the Documentation this important notes about NAT order of operation?
Lorenz
You can find this order over here-
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/mr.htm#wp1032129
Though above link is based on 6.x code, the order of nat operations is still the same in 7.x code. I hope this answers all your concers :-)
This is great! Thank you Sir!
