Compliance Check with RME
I'm trying to use RME compliance check but it doesn't seem to work correctly.
If I define a template like this
Name: Global SubMode: Yes isPrerequisite: No
Ordered : No Prerequisite-Commandset : none Parent: none
IP SLA 6
+ frequency 500
All my devices are always compliant even when it is not the case.
If I change frequency 500 with 600 for example, they are still all compliant.
It is like this template doesn't do anything.
It does work if I test on sub interface like Fe0 for example.
How can I test compliance for sub-commands other than interfaces?
Joe Clarke Thu, 02/15/2007 - 12:04
This is probably because you don't have the "ip sla 6" operation configured. You could try doing this using two commandlets:
Name: SLA6 SubMode: No isPrerequisite: No
+ ip sla 6
Name: SLA6Freq SubMode: Yes isPrerequisite: No
ip sla 6
+ frequency 500
I've just tried the example RME template called "TemplateExample2"
Name: parent SubMode: Yes isPrerequisite: No
policy-map V3PN-teleworker
# No commands
Name: child SubMode: Yes isPrerequisite: No
Ordered : No Prerequisite-Commandset : none Parent: parent
class VOICE
+ priority 64
I configured the router with "priority 62"
then ran the compliance test.
And the router config came back as compliant again.
kyawzawhtut Thu, 02/22/2007 - 17:41
Is yr news confirmed that LMS 3.0 is schedule to released in May?
I wish LMS can be more stable not memory intensive.
I also wish that DFM module can act intelligently like other products such as HP OV NNM, CA eHealth when tackle the fault and events.
All Hail..King Of The Network!! :D
Cheers!
