CCNA Lab setup recommendations: Have equipment
Feb 15th, 2007
I am currently prepping for CCNA test and will most likely head for a CCNP and CCSP in the future.
Currently, I have the following equipment at home:
2610 router
1720 router
PIX 501 firewall
What I would like to do is setup some type of lab at home that I can play with. I have a cable modem connection, so I was thinking I could some how tie this all together in a mini-network so I could practice. Maybe I could even get a switch of some sort.
Things I want to learn:
-PIX/ASA Firewalls (have 6.3 on the PIX)
-routing, routing protocols, routed protocols
-IOS using CLI
Anything else that will help prep for my CCNA test.
Is their a suggested curriculum out their, a lab book of some sort that would help me put together some scenarios?
Does anyone have recommendations on how I could setup my lab while hooked up to my cable modem?
Something like:
modem --> PIX --> 2610 --> 1720 --> LAN
Any recommendations are appreciated.
Jason
Overall Rating: 3 (1 ratings)
ellis_b Thu, 02/15/2007 - 22:00
Jason,
What I suggest you purchase is a 2511 or 2509 and then connect that via the ethernet to your pix. Setup a static nat for port 23 to your public ip address. Then, connect the 2511 or 09 via an octal cable to the devices in your lab (the 1720 and 2610). I recommend you purchase a 2950 switch as well. That should give you a good start and provide remote access to your home lab.
thanks,
Brad Ellis
CCIE#5796 (R&S / Security)
CCSI#30482
Network Learning Inc - A Cisco Sponsored Organization (SO)
YES! We take Cisco Learning credits!
[email protected]
www.ccbootcamp.com (Cisco Training and Advanced Technology Rental Racks)
www.routerie.com (Routing and Switching Forums)
www.securityie.com (Security Forums)
www.voiceie.com (Voice Forums)
Voice: 702-968-5100
FAX: 702-446-8012
