3845 and NME-16ES-1G
Feb 15th, 2007
I have a 3845 router with two NME-16ES-1G installed. When I do a service-module gigabitEthernet 1/0 status. The service module never goes into a steady state. All I get is Service Module is waiting for registration message.
I moved the service modules to another slot on the router and it still never goes into a steady state.
Do I have bad service modules?
rebecca.richards Sun, 02/18/2007 - 20:52
Have you assigned an IP address to each of the virtual Gig interfaces? What happens if you run the command "service-module gi 1/0 session"? Do you get to the switch prompt?
Maybe the status changes when there is a proper configuration within the switch, such that it can communicate via the "GigE" connection between the two devices....
Having a look myself, the following is output from a 2811 with an NME-16ES-1G-P, the router being configured, but the NME being unconfigured.
rtr01.blah#service-module gi1/0 status
Service Module is Cisco GigabitEthernet1/0
Service Module supports session via TTY line 66
Service Module reset on error is disabled
Service Module status is not available
rtr01.blah#service-module gi1/0 session
Trying 10.1.2.5, 2066 ... Open
User Access Verification
Username: admin
Password:
(some stuff about autoinstall...)
Switch>en
Switch#wr t
Building configuration...
Current configuration : 1098 bytes
version 12.2
no service pad
These NME cards are dead-set "weird". I'd love to have a nice and clean configuration for them. I'm still racking my brain trying to work out how to get VLAN's to work between the router and switch.
- Rebecca
