Begining frame-relay
Answered Question
Feb 15th, 2007
Hello All,
Can some please take the pain to take me through each step in configuring a frame-relay plz?
I'm determined for CCNA and cannot afford the tuition but can afford three routers as explained by the book im using. Unfortunately i cannot gather all the wants me to get(probably misconception) in order to set-up frame relay.
Please i need the steps to guide as if to a lay man i.e what goes from one router to the other, type of cable to link them etc and to what port, how the remaining two routers will particiapte etc
Hope somebody can help?
Correct Answer by CSCO10892433 about 9 years 7 months ago
Hi, newnetman
Here is the step-by-step
1.Go to ebay and buy the following stuff
One set of 4-serial port router. Two affordable options are 2520 and 2610+NM-4A/S.This will be your frame-relay switch
Three set of 2-serial port routers. To make things simple, I would suggest 2501(it has 2 fixed serial port) or 2610+WIC-1T(in this case, you have only 1 serial port, but it is not a problem for our lab building)
three pieces of Back to Back DCE/DTE DB60 Crossover Cables. You might want to add one cable to connect 2 routers(not frame-relay) so you can practice PPP without the need to re-wire the cable.
2.Connect each router according the following cabling plan
FR.s0R1.s0
FR.s1R2.s0
FR.s2R3.s0
R1.s1R2.s1 (Suppose you have additional cables and additional ports)
Each cable has one side marked as DCE and the other side marked as DTE. To make things simple we choose the DCE site to be connected to the FR and the DTE site to be connected to a normal router.(FR.s0 means serial port #0 of Frame-relay switch, FR.s1 means serial port #1 of Frame-relay switch,etc)
3.Copy the commands I write on the attached file and paste to your Frame-Relay
Here I give you 3 PVCs :
R1.s0.102<--->R2.s0.201
R1.s0.103<--->R3.s0.301
R2.s0.203<--->R3.s0.302
If you want create your own pvcs with different value, just substitute the above numbers to your own
4.Last step. Finish the PVC on R1,R2, and R3, but for being a CCNA candidate, that's what you must know and configure it by yourself, isn't it?(Anyway, if you still feel difficult on this step, just let me know.)
Good Lucks
SSLIN
P.S. It takes me a while to write this step-by-step. I'm happy doing it. I feel no pain.
Overall Rating: 4 (1 ratings)
Correct Answer
CSCO10892433 Thu, 02/15/2007 - 23:40
Hi, newnetman
FR.s0R1.s0
FR.s1R2.s0
FR.s2R3.s0
Good Lucks
SSLIN
newnetman Fri, 02/16/2007 - 11:45
Hi SSLIN,
I cannnot be greatful enough with
this wealth of knowledge you have imparted on me and many others (unknown readers).I'm MOST GREATFUL MATE most especially for the precious it took you to help me.
Again,i have acquire two routers already (2 x 2500 with ver 12.3). With these i have two serial port each 0 and 1 but is like your step 2 guide requires 3 serial ports, plz correct if im wrong?.
In that case, should i make the third router (to be bought) a 3 ports one (2610+NM-4A/S)?
possibly in addition to these 2 router already mention, could you please give me a link if possible to a possible third viable router on ebay or elsewhere?
May you be abundantly reward by our Good God in heaven as you have tremendously blessed me too.
ahmednaas Fri, 02/16/2007 - 12:00
The most used route in labs for FR switching is the 2522 (with 8 A/S ports). The 2520 is cheaper but has only a total of 4 serial ports.
CSCO10892433 Tue, 02/20/2007 - 00:09
Sorry for the late reply.
The reason why I suggest a 4-serial-port routers is that a lot of senarios regarding the frame-relay you will encounter in the future is based on a "hub-and-spoke" topology -- one hub router and at least two spoke routers.Each router connet to one serial port on the frame-relay switch. So the router functioning as a frame-relay switch need at least three serial port.
In your case, another 2-serial-port router might meet your needs now, but I believe, as you study more and more in the future, you will need the forth router(or more?) very soon.
As for the link, you can go to ebay website, type the following keywords in the serach box:
cisco 2520
cisco 2522
cisco 2610
NM-4A/S
NM-8A/S
I believe you can find what you want.
Good Lucks
SSLIN
