12.2(18)SXF3 bugs
aksher
what are the bugs in 12.2(18)SXF3 affecting BGP.
spremkumar
Level 9
Level 9
Hi Aksher
Better check out bug toolkit to find out the bugs listed for this particular ios version or else go to software advisor tool where you can find out the bugs related to the ios version as well as to the particular feature set..
regds
hoogen_82
Level 4
Level 4
CSCsb50606
Headline: Leak in dead process due to TCBs from BGP active connections
The above seems to be the only BUG
Hoogen
Do rate if my post helped you :)
