Connecting 3550 to 3650 fiber channels
Feb 15th, 2007
I will be purchasing a new Catalyst 3650 and I have a question about properly connecting it to my existing 3550 using the GBIC Ports. The 3550 have the Standard GBIC connectors and tbe 3650 have the mini GBIC ports. Can I simply purchase an SC connector and a LC connector and a cable that terminates on each end to the respective connector or are there other things I need to consider?
Mike
1 vote
dahuja Thu, 02/15/2007 - 16:20
Hi Mike
Yes you are thinking in a right direction but kindly refer the links for software compatibility and Installation notes.
GBIC and SFP Software compatibility Matrix
http://www.cisco.com/univercd/cc/td/doc/product/gbic_sfp/gbic_doc/ol_6981.htm
GBIC and SFP Installation and Specifications.
http://www.cisco.com/univercd/cc/td/doc/product/core/7200vx/72vxfru/5067g.htm#wp24439
I hope this helps and please feel free to contact me for any further query.
Warm Regards,
Deepak Ahuja
Cisco Tac
