Point-to-point connection between to linksys
Feb 15th, 2007
I have Two Linksys WAP54G Wireless-G Access Point, is it possible to connect to two houses in mode bridge using these applainces,
I am thinking about buying an antenna Cisco Aironet 13.5dBi 2.4 GHz Yagi Mast Mount Antenna with RP-TNC Connector.
Some one who knows about this, that can help me?
balajitvk Mon, 02/19/2007 - 20:43
Hi jamco,
Yes, You can... Linksys WAP54G has only three modes. These are, the basic access point mode and the wireless bridge mode ? point-to-point and point-to-multipoint.
The web interface does not specify whether the bridge mode is point-to-point or point-to-multipoint, as compared to the WAP11 device. Which makes sense, because you don't have to. If you enter only one MAC address, then it would be a point-to-point connection with another access point acting as a wireless bridge. If you enter more than one, then it's a point-to-multipoint wireless bridge connection ? less options, less clutter and a simpler interface.
If you're thinking of buying an access point to act as a wireless repeater or a wireless client, then WAP54G is not for you, as these modes are not present in the unit.
Hope this will help you!
Rate if it does,
Rgs
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
