PGW & Siemens
exchange1
I have a PGW connected to a PSTN (Siemens EWSD) for a prepaid calling card platform. I can dial into the cisco platform but when I route the call back to the same PSTN, the PSTN sees the calling number prepended with 009.
Below is the SS7 trace from the PSTN showing the owner DN 00915925 instead of 15925 (Although I noticed in the trace the NAI is international while the PSTN is expecting national).
I need help,
ABJPC/ABW.523/NIACPK1V16316934/103 07-02-15
17:47:49
9134 OMT-01/MUSA 2959/20044
DISPCHAREC:TYPE=IACAMA,ICTGNO=BSCOPO,BEGDATE=07-02-15,
BEGTIME=17-35-00,ENDDATE=07-02-15,ENDTIME=17-40-00,ALL=Y;
DISPLAY OF IACAMA RECORD
FLAGS : SINGLE CHARGE ANSWER IACAMA CONN
OWNER DN : 00915925
CALLING PARTY : 15925
NADI: 4 =INTERNATIONAL NUMBER NPI: 1=ISDN NUMBERING PLAN
SCR.IND.: 1=USER PROVIDED PASSED PRES.IND.: 1=RESTRICTED
CALLED PARTY : 84232222
NADI: 3 =NATIONAL NUMBER NPI: 1=ISDN NUMBERING PLAN
DATE TIME DURAT: 2007-02-15 17:38:09 3 BEGTIME SECURE 23
SEC
PARTNER DN : 084232222
TMR : 1 =SPEECH
CHARGE UNITS : CONN= 0
DUR B. ANSWER : DT-ACM = 1 ACM-ANS = 3
QUALITY DATA : CAUSE= 38 LOCATION= 2 CODING STANDARD= 0
TRUNKID : TGNO-LNO :INC= BSCOPO-1 OG= BENUSC-1009
CONNECTION ID : H'0A910300
INTERRUPTION TEXT JOB 9134
teodorgeorgiev
Level 4
Level 4
This is because number normalisation is configured in your trunkgroup that is "responsible" for processing this call.
Read this guide:
http://www.cisco-ct.com/univercd/cc/td/doc/product/access/sc/rel9/mgcfm/941fm/fmrednum.htm#wp1072993
I am able to resolve the problem by setting the NAI to "national" which corresponds with what the PSTN wants. Since my PGW is in signaling mode I used the command "linexlate" to make the changes.
