Forgot Passwor On SSM-10
Feb 15th, 2007
Dear Sir,
Now i have problem,I forgot the password on SSM-10 (ASA5510).
How to resetpassword on SSM-10 Module?
Best Regards,
vitripat Sun, 02/18/2007 - 11:23
If your ASA is running on 7.2(2) code, then its pretty simple. It can be done using a single command:
hw-module module password-reset
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_7_2/rel_note/asarn722.htm#wp128580
However, if you are on a version older than 7.2(2), then we need to reimage the SSM module to recover the password. Here is a link which explains the procedure:
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a00805521b6.html#wp1049302
Vibhor.
nareth_norung Mon, 02/19/2007 - 19:11
Dear Vibhor,
It's great to see your email.Thank you for your support.My ASA version 7.1(2).By the way Can i ask you one more question? I want recovery ssm than i type command:
+hostname# hw-module module 1 recover configure.
+URL [tftp://171.69.1.129/dqu/sg-6.0-1345-tftp.img](I don't understand tish line : dqu/sg-6.0-1345-tftp.img, and How can i get img file?
I'm waiting your email as soon as.
Best Regards,
vitripat Tue, 02/20/2007 - 08:37
Ok .. I'm assuming that you need explanation about following string:
Image URL [tftp://1.1.1.1/IPS-SSM-K9-sys-1.1-a-5.0-0.15-S91-0.15.img]
"IPS-SSM-K9-sys-1.1-a-5.0-0.15-S91-0.15.img" this is a system image file which can be downloaded from following link:
http://www.cisco.com/cgi-bin/tablebuild.pl/ips5-asa-aip
(A valid CCO ID with software level access is required)
For this procedure, you essentially need a system image file. A normal signature update file will not work.
Vibhor.
