Unity3.16 VM only w/Exchange2K Installation issue---The Exchange Domain...
master001
Level 2
Level 2
Hi there,
Recently I have been practicing Unity 3.16 VM only w/Exchange2K installation.
After I finished Unity file installation ,Unity service configuration windows showed up, got this message:
The Exchange Domain Servers group could not be found in the following domain:\\ (domain name).
Has anybody met this issue before? (The Unity3.16 is Domain Controller.) Is it doing with UnityInstall account permission setup? which steps?
Thanks.
mchandak
Level 7
Level 7
Is Exchange installed on the same box as Unity or on a different machine and if the server is a part of the same domain as Unity.
Note that Unity 3.1 has gone end of support and end of life. I'd recommend using a 4.x train.
Thanks for your reply.
Exchange installed on the same box. And it is for testing.
Problem fixed. It is DNS problem.
