mpls l2transport route cause VC down
Answered Question
Feb 16th, 2007
dear all,
i have an issue concerned when i configure AToM to enable router to transport ATM aal5 between two PErouter
topology as below:
ATM ==PErouter1==MPLS-cloud==PErouter2== ATM
before I implement "mpls AToM" I configure it as:
=PErouter1=
interface ATM1/0/0
no shut
interface ATM1/0/0.1
pvc 0/164 l2transport
then i tried loopback testing for pvc (ping atm interface atm1/0/0.1 0 164 end). the test was okay (i got reply)
but when i put command :
int atm 1/0/0.1
pvc 0/164 l2
mpls l2transport route 172.30.248.32 610000
the pvc line between perouter1 and atm is down.
i tried ping atm interface atm1/0/0.1 0 164 end, the result is 'request timeout'
the same case is happened in both perouter.
sh mpls l2 vc
Local intf Local circuit Dest address VC ID Status
AT1/0/0.3 ATM AAL5 0/166 172.30.248.32 610000 DOWN
cisco-pe#sh mpls l2 vc detail
Local interface: AT1/0/0.3 up, line protocol up, ATM AAL5 0/166 up
Destination address: 172.30.248.32, VC ID: 610000, VC status: down
Tunnel label: not ready, LFIB entry present
Output interface: unknown, imposed label stack {}
Create time: 00:04:40, last status change time: 00:02:11
Signaling protocol: LDP, peer 172.30.248.32:0 up
MPLS VC labels: local 995, remote 1502
Group ID: local 83, remote 193
MTU: local 4470, remote 4470
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
from logg i found :
Feb 16 02:36:23.049 JAVT: %C6K_MPLS_COMMON-3-L3_CONFIG_NOT_RECOMMENDED: LAN interfaces have MPLS configured.
Do not configure xconnect on interface vlans.
Feb 16 02:36:27.433 JAVT: %IPC-5-WATERMARK: 907 messages pending in rcv for the port Card5/1:Request(2150000.5) seat 2150000
Feb 16 02:36:27.461 JAVT: %LDP-5-NBRCHG: LDP Neighbor 172.30.248.32:0 is UP
Feb 16 02:36:57.498 JAVT: %IPC-5-WATERMARK: 907 messages pending in rcv for the port Card5/1:Request(2150000.5) seat 2150000
Feb 16 02:37:27.562 JAVT: %IPC-5-
please help me,
thx
Rano
Correct Answer by alexander.muhin about 9 years 7 months ago
hmm.. didn't hear about such
sorry
regards,
Alex
Overall Rating: 3.5 (2 ratings)
alexander.muhin Fri, 02/16/2007 - 00:52
Hi Rano,
what hardware do you have (including core facing interfaces)?
Show LFIB of your PE routers. It would be nice if you show configs of both PE routers (interfaces: edge, core; mpls part etc).
regards
Alexander
cripth Sun, 02/18/2007 - 21:13
Hi Alex,
i'm sorry i can't provide you anything about MPLS part, because that beyond my scope. but i can provide info about pe router config in attachment
cisco-PE1 = 6509
cisco-PE2 = 7609
and both are using card 4-subslot SPA Interface Processor-400
is there any problem with configuration or there are something that i missed it.
thx
Rano
alexander.muhin Mon, 02/19/2007 - 13:53
I think the configuration is ok.
It seems you have a lan card as a core-facing interface.
ATM AAL5 over MPLS Restrictions
The following restrictionapplies to the ATM AAL5 over MPLS feature.
•Both CE-facing and core-facing cards must be WAN cards (enhanced OSMs, FLexWAN and Enhanced FlexWAN modules) and not LAN cards.
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/cfgnotes/optical/122sx/mpls.htm#wp1282153
SUP720-PFC3B-based systems and SUP720-PFC3BXL-based systems require that the core-facing cards must be CWAN cards (enhanced OSMs, FlexWAN and Enhanced FlexWAN modules, and Shared Port Adapter [SPA] Interface Processors [SIPs]). This applies to CWAN-based Ethernet over MPLS, ATM AAL5 over MPLS, ATM Cell Relay over MPLS, and Frame Relay over MPLS.
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a00803f3770.html#wp1426121
hope this helps,
Alexander
cripth Wed, 02/21/2007 - 19:45
thx a lot for the info lex,
i'm sure it is because of core-facing card too.
but do you have any solution for this issue, like upgrading IOS beside changing core-facing WAN interface, because it's gonna take lot of time to implement it (ordering, shipping, etc).
thx
rano
