IP Phone services for CCM5.1
stephan.steiner Mon, 02/19/2007 - 01:18
What makes you think your path is valid?
Did you copy ASP files to that particular location?
Furthermore, what makes you think you can run ASP pages (which are inheritently Microsoft IIS based) on a Linux machine? You may be able to run ASP.NET pages by installing Apache and Mono on Linux, but forget about ASP pages. While we're at it, forget about running any third party apps on the call manager - with CCM 5.x that's simply not an option anymore, you really need your application server for that (and there you could use Windows which then would permit you to run ASP applications again).
Keep in mind, apps are meant to run on a separate machine, and plain XML apps that do not make use of LDAP, SQL or AXL (serviceability) will run on any CCM release and just depend on the phone load.
gadacha-fouad Mon, 02/19/2007 - 03:49
Thanks for your help.
Where can I find asp sources for the calendar service ?
