topology map in CM device unknowm
Feb 16th, 2007
I use switch 3560G-24TS.In device center the type of device is very well specified but it appears unknown in topology map.it is just specified ciscoProducts.615.What I must make for visualizing the device well
David Stanford Fri, 02/16/2007 - 06:14
Which version of CM are you running? I see that the 3560G-24TS is supported in CM 4.0.3.
diaration Sat, 02/17/2007 - 08:15
I'm running CM version 4.0.3 and 3560G-24TS is in device package but for may topology map it is view as unknown device. Help me please.
sathappan Sat, 02/17/2007 - 21:35
If you are using LMS2.5.1, upgrade it to LMS2.6. I had a similar problem for access points, and after upgradation the problem was solved.
sathappan.s
Anonymous (not verified) Sat, 02/17/2007 - 22:03
David Stanford Tue, 02/20/2007 - 07:50
Sorry, my mistake above...was thinking it was 4.0.3, when it was 4.0.4 (read the wrong table)....thanks for correcting
