ACCESS LIST ISSUES??
Answered Question
Feb 16th, 2007
I have a Main Router Cisco 871 and 5 remote sites using the Cisco 850. The tunnel comes up fine and can ping back and forth from the 850 to the 871. However I think I have an access list issue because I can't seem to open the Main Database that is at the Main site from any of the 5 locations nor can I get on the internet as the proxy server not getting to the other sites. I can ping these from remote sites but can't actually use them. These rules are much different then from the PIX.
***192.168.1x
** FROM REMOTE LOCATION
access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
route-map nonat permit 10
match ip address 101
***192.168.0.X
***FROM MAIN ROUTER
logging trap debugging
access-list 100 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 101 deny ip 192.168.0.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 permit ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 103 permit ip 192.168.0.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 104 permit ip 192.168.0.0 0.0.0.255 192.168.5.0 0.0.0.255
no cdp run
Correct Answer by ggilbert about 9 years 7 months ago
ip tcp mss <68-10000>
Hope this helps,
gilbert
Overall Rating: 5 (1 ratings)
kaachary Fri, 02/16/2007 - 05:36
It doesn't seem to be an ACL issue, as you are allowing all "ip" traffic to go through the tunnel. What do you mean by " can ping these from remote sites but can't actually use them" ? Could you please elaborate.
Also, You might want to check the access-groups applied on the inside LAN interfaces, if there's any.
HTH,
-Kanishka
cozyk1515 Fri, 02/16/2007 - 05:50
Sorry, I am able to ping the IP address of the database from the remote.
Database: 192.168.0.50 at main
can ping this address from 192.168.1.x but can't use it.
*******MAIN CONFIG
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp policy 3
encr 3des
hash md5
group 2
crypto isakmp key XXX address X.X.X.X
crypto isakmp key xXX address X.X.X.X
crypto isakmp keepalive 20 5
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map bhsn 10 ipsec-isakmp
description VPN to PARC
set peer X.X.X.X
set transform-set myset
match address 100
crypto map bhsn 20 ipsec-isakmp
description VPN to Corneilia
set peer X.X.X.X
match address 102
crypto map bhsn 30 ipsec-isakmp
description VPN to OAK
set peer X.X.X.X
match address 103
crypto map bhsn 40 ipsec-isakmp
description VPN to Wells
set peer X.X.X.X
match address 104
interface FastEthernet4
description 5Mb WAN
ip address 216.x.x.x 255.255.255.128 secondary
ip address 216.x.x.x. 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
crypto map bhsn
interface Vlan1
description Default Gateway fa0-fa3
ip address 216.X.X.X 255.255.255.248 secondary
ip address 192.168.0.11 255.255.255.0
no ip redirects
no ip unreachables
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
ip classless
ip route 0.0.0.0 0.0.0.0 216.x.x.x.
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nonat interface FastEthernet4 overload
no cdp run
**** REMOTE SITE
encr 3des
hash md5
group 2
description Connect to main BHSN
set peer X.X.X.X
match address 100
description WAN
ip address 216.X.X.X 255.255.255.224
ip nat outside
duplex auto
speed auto
crypto map bhsn
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip directed-broadcast
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip http server
no cdp run
kaachary Fri, 02/16/2007 - 06:03
If ping works, then it is most likely be a packet size issue. Can you try lowering down the TCP MSS on LAN interfaces on both the routers.
HTH,
-Kanishka
Correct Answer
ggilbert Fri, 02/16/2007 - 10:33
Hope this helps,
gilbert
ggilbert Fri, 02/16/2007 - 10:53
Can you go into the LAN side where the server is and see if you can change the mss.
conf t
interface
ip tcp adjust-mss <500-1460>
Set the mss to something like 900 and see if that works. If it does, please increase by 100 (900 then 1000 then 1100) and see if that helps.
Gilbert
