announcement ?
Feb 16th, 2007
I have AS5350 connected to IP-network from one side and to PBX (ISDN) from other side. Then a user of PBX placing a call to the AS5350 it get an announcement but then user placing a call to some another numbers it geting ringback but it must also get an announcement. How can i solve the problem ?
Here is debug isdn q931 for this two calls:
1. with announcement
02:23:20: ISDN Se3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x001C
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839B
Exclusive, Channel 27
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '99544295015'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '79181035089'
02:23:20: ISDN Se3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x801C
02:23:24: ISDN Se3/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0x801C
Cause i = 0x8194 - Subscriber Absent
02:23:52: ISDN Se3/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x001C
Cause i = 0x8190 - Normal call clearing
02:23:52: ISDN Se3/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x801C
02:23:52: ISDN Se3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x001C
2. without announcement (but it must be):
02:30:38: ISDN Se3/0:15 Q931: RX <- SETUP pd = 8 callref = 0x001A
Sending Complete
Standard = CCITT
Channel ID i = 0xA98399
Exclusive, Channel 25
Called Party Number i = 0xA1, '79284592406'
02:30:38: ISDN Se3/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x801A
02:31:04: ISDN Se3/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x801A
Progress Ind i = 0x8188 - In-band info or appropriate now available
02:31:05: ISDN Se3/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0x801A
thomas.chen Thu, 02/22/2007 - 07:06
Different components inside Cisco IOS software work together to enable remote clients to dial in and send packets. Figure 2 shows one Cisco AS5300 access server that is receiving calls from a remote office, branch office (ROBO); small office, home office (SOHO); and modem client.
Depending on your network scenario, you may encounter all of the components. For example, you might decide to create a virtual IP subnet by using a loopback interface. This step saves address space. Virtual subnets can exist inside devices that you advertise to your backbone. In turn, IP packets get relayed to remote PCs, which route back to the central site.
Try:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00800ca6ea.html
