Using WEP w/ DOS based PC and 350 card.
Feb 16th, 2007
We are currently using a DOS based PC that runs only a 5250 emulator. We connect to the network via a Cisco 350 card on a wide open wireless network. We have successfully set one of these units up to run of WEP side of our wireless. But all other units we cannot get to connect. We have tried loading all the different firmwares for the 350 card. All of the 4.x firmwares load fine and sets WEP key but won't connect to network. When we load the 5.x versions of the firmware, we get a Error Accessing Card: 8007 error when loading WEP key. We are wondering how to be able to get around this 8007 error, to be able to successfully try to connect with the newest firmware of the 350 card. Any thoughts?
gmarogi Thu, 02/22/2007 - 07:18
If you have windows version you can use that to setup the WEP keys.For the version 5.x there is no explicit mention for the support of DOS.For using DOS version 4.x seems to work fine.The DOS utilities run well under MS-DOS 6.22. For the PCM350 and LM350 PCMCIA cards, the DOS utilities do not use card and socket services for configuring the cards; they program the PCMICIA socket directly. Therefore, an 82365-compatible socket controller is required for proper operation. Many, but not all, socket controllers have this capability. Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350cards/msdos/instlcfg/dosutil.htm#wp1004697
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
