Cisco 800 series easy vpn server issues.
Answered Question
Feb 16th, 2007
Hello.
I want to deploy easy vpn server on 10 cisco 877 and 876 routers and access them from a remote location (company HQ).When i leave the router firewall off the vpn server works.When i turn it on it doesn't.
Although i allow all traffic from my ip eg 80.76.61.158 i cannot access the vpn server.
I tried from a location to leave the firewall off and it worked fine.
I use SDM to configure the vpn server.Any ideas what i can do with the firewall cause i really cannot leave it "open".
Thanks in advance.
Correct Answer by Kamal Malhotra about 9 years 7 months ago
It would be a good idea to paste the configuration of the VPN server with firewall on.
Kamal
Overall Rating: 5 (1 ratings)
kaachary Fri, 02/16/2007 - 12:47
Can you post the rules you have in the inbound ACL applied to outside interface ?
-Kanishka
Correct Answer
Kamal Malhotra Fri, 02/16/2007 - 15:03
Kamal
tkatsiaounis Wed, 02/21/2007 - 05:46
I havent got the configuration i shut down the firewall and i cannot do anything now. Any guidelines to follow?A working example possibly??
