isdn sending-complete -what does it do?
Feb 16th, 2007
Trying to figure out what it does and if it will solve a problem with ISDN users not being able to dial in?
At the moment analogue users are able to dial in and connect but the ISDN users get disconnected immediately.
We make use of a windows auth server which has been configured on the router.
Looking at cisco docs but not finding a solution ....not quick enough that is ...
Please help
ahmednaas Fri, 02/16/2007 - 08:37
Here is with the manual says:
_____________________________________________
Configure the voice port to include the Sending Complete information element in the outgoing call setup message. This command is used in some geographic locations, such as Hong Kong and Taiwan, where the sending complete information element is required in the outgoing call setup message.
It seems to be an outgoing call setup command needed for some exchanges in the far east. So it is not likely to help in resolving your issue.
