02-16-2007 08:30 AM - edited 03-14-2019 08:04 PM
Is there a way to get to the moh audio source files after you convert them in callmanager. I need to convert the taps prompts to g.729 and cannot find the files anywhere?
02-16-2007 08:58 AM
Hi Mike,
You can download the files from CCO so you have a fresh set;
** I just looked and these files can be found at the attached link with CCO Login (Right down towards the bottom of the page)**
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-33
Hope this helps!
Rob
02-16-2007 09:03 AM
not seeing it is it under taps or something else?
02-16-2007 09:14 AM
Hi Mike,
It is right at the bottom of the page. Try this link;
Hope this helps!
Rob
02-16-2007 09:19 AM
if u are referring to a file which was used for MoH and you want to use it again, you can get the g.729 format of the same file from the TFTPPath folder (C:\Program Files\Cisco\TFTPath). This folder would have the file in the following formats for all the audio soucres:
G711alaw
G711ulaw
G729
WideBand
