2651 and the WIC-1DSU-T1-V2
jfarrer
I have put two WIC-1DSU-T1-V2 modules into my 2651 and I am not able to configure them. A 'show diag' command shows the modules, part number, serial number, etc. I ran this configuration through the software advisor and it claimed that I could use the V2 cards and gave me a couple of IOS images, which I loaded one. I have found one or two documents that say you can't use them. Does anyone know for sure whether or not the V2 cards will work in the 2651?
Jack
virenderj
WIC-1DSU-T1-V2 is only supported in 2600Xms or 2691.
