Syslogging from ASA5505 and PIX-506 over IPSEC Tunnel
I have a customer with many remote sites using either ASA5505 or a PIX-506. There is IPSEC tunnel to each remote site from the hub site. The remote site doesn't have a server. The goal is send syslog and traps to the server located at main site.
The Encryption domain is inside interface subnet at each site. I didn't find any command that syslogs or sends traps with source ip being inside interface.
Any ideas?
Its not a clean way but I guess the only way.
I was hoping it would do like NetScreen firewalls where you can tell the firewall to source the syslog from inside interface even though the destination is somewhere on outside. That way you don't have to fiddle with interesting traffic.
Hopefully some customer with good leverage submitted a PERS to cisco ;-).. I always wondered why companies don't put "Wish List" link on their website. They can collect a lot of good ideas for free :-)
Thank,
Sam
By the way the example URL has a little mistake in it. The ACL should be like below.
access-list 101 permit tcp host 192.168.1.2 eq 161 host 172.18.124.112
access-list 101 permit udp host 192.168.1.2 eq 161 host 172.18.124.112
access-list 101 permit tcp host 192.168.1.2 host 172.18.124.112 eq 162
access-list 101 permit udp host 192.168.1.2 host 172.18.124.112 eq 162
access-list 101 permit udp host 192.168.1.2 host 172.18.124.112 eq 514
For traps and syslog ACL is correct. However the replies for snmpget would be in reverse port order. e.g. main site making calls to public IP of remote box on port 161.
I am surprized it worked for Cisco engineer who wrote the document and posted in configuration example.
acomiskey Fri, 02/16/2007 - 11:36
^^agreed
also what are these for then on the local pix
access-list 101 permit tcp host 172.18.124.112 host 192.168.1.2 eq 162
access-list 101 permit udp host 172.18.124.112 host 192.168.1.2 eq 162
access-list 101 permit udp host 172.18.124.112 host 192.168.1.2 eq 514
the snmp/syslog server is not sending traps or syslog to remote pix
I agree with you if this was a router. These are ASA5505s and PIX-506s. There is no such command as "logging source-interface".
Detroit-ASA5505(config)# logging ?
configure mode commands/options:
asdm Set logging level or list for ASDM
asdm-buffer-size Specify ASDM logging buffer size
buffer-size Specify logging memory buffer size
buffered Set buffer logging level or list
class Specify logging event class
console Set console logging level or list
debug-trace Enable logging of redirect debug-trace output to
syslog
device-id Specify the device-id to be included in all
non-EMBLEM formatted syslog messages
emblem Enable logging Emblem format on all output
supported destinations
enable Enable logging to all output supported destinations
facility Specify the syslog facility, the default is 20
flash-bufferwrap Save logging buffer to flash when buffer
wrap-around
flash-maximum-allocation Specify logging maximum flash space allocation
flash-minimum-free Specify logging minimum flash free space threshold
from-address Specify the from address for the mail logging
ftp-bufferwrap Save logging buffer using FTP when buffer
wrap-around
ftp-server Specify FTP server parameters
history Set the SNMP message level or list for sending
syslog traps
host Send syslog messages to a host
list Specify logging event list
mail Set mail logging level or list
message Specify a message to be allowed
monitor Specify that syslog messages appear on Telnet
sessions to the Firewall console
permit-hostdown Allow new connection even if TCP syslog server is
down
queue Specify queue size for storing syslog messages,
default is 512, 0 means unlimited (subject to
available memory)
rate-limit Specify logging rate-limit parameters
recipient-address Specify the mail logging recipient address and
level
standby Enable logging on standby unit with failover
enabled, warning: this option causes twice as much
traffic on the syslog server
timestamp Enable logging timestamp on syslog messages
trap Set logging level or list for syslog server
