2811 not seeing WIC
Feb 16th, 2007
I have 2 2811s and both do not see the T1 WIC.
virenderj Fri, 02/16/2007 - 11:03
Please share the WIC part no. and "show inventory" output of the router.
slotking22 Fri, 02/16/2007 - 13:45
I found that 1 router sho diag has disabled the WIC:
WIC Slot 0:
FT1 BT8360
WIC module not supported/disabled in this slot
But the WIC in the 2nd router is OK, but does not show as a serial interface:
Sho diag info:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-04
sho inven info:
#sho inv
NAME: "2811 chassis", DESCR: "2811 chassis, Hw Serial#: FTX1004C0CQ, Hw Revision: 52.57"
PID: CISCO2811 , VID: V02 , SN: FTX1004C0CQ
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC100126PE
slotking22 Fri, 02/16/2007 - 14:12
tried it on rtr 1
it seemed to work, it took the command with no errors,
BUT
when I go to check the interfaces, still no serial interface
slotking22 Fri, 02/16/2007 - 14:55
ok, the 1 wic card works in both units. The other wic does not work in either.
I have 1 rtr with a serial interface now!
thank you
Danilo Dy Tue, 02/20/2007 - 07:36
Check the version of the card as there are minimum version that 2811 can support. You need V2.
