DACL from ACS 4.0 to Cisco IOS
Feb 16th, 2007
Cisco ACS Documentation claims that Cisco devices running IOS version 12.3(8)T or greater support Downloadable IP ACLs.However is almost impossible to find a documentation regarding this configuration.The only documentation available are those describing DACL to PIX or ASA but there shouldnt be any difference with the DACLs to IOS configuration.Thus, i really wanted to know if there is anyone who actually managed to make this work and if you have any idea what might be the reason mine configuration have failed it would be much appreciated.
IPsec Remote Access Using Preshared Key
VPN Client:4.7
transport:IPSEC/UDP
Cisco Router: 3640
Cisco IOS:Version 12.3(11)T10
AAA:Radius(ACS)
ACS version 4.0 for windows
Router configuration:
aaa authentication login userauthen group radius
aaa authorization network groupauthor group radius
aaa accounting update periodic 1
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop broadcast group radius
aaa accounting connection default start-stop group radius
aaa accounting system default start-stop group radius
aaa accounting resource default start-stop group radius
aaa session-id common
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
no crypto isakmp ccm
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap client accounting list default
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
radius-server host x.x.x.x auth-port 1645 acct-port 1646
radius-server key xxxxxxxx
radius-server vsa send accounting
radius-server vsa send authentication
ACS Configuration:
Here i just created a Downloadable access list and gave the following rule: "permit icmp any any" and name:"test".
Next i opened a user's setting and checked the box "Assign IP ACL" and chose the name of the DACL i created.
Am i missing something here?
When the ACS is authenticating the user it seems from the "debug radius authentication" that ACS sends the DACL "test" to the router:
Feb 16 22:28:32.402: RADIUS: Cisco AVpair [1] 59 "ACS:CiscoSecure-Defined-ACL=#ACSACL#-IP-test-45d6210d"
However when i enter the command sh access lists i dont see the access list #ASCACL#(btw i havent configured any other acl on the router) and ofcourse the user has unlimited access to the network(it should have only icmp)
Thanks in advance for your time
Overall Rating: 5 (1 ratings)
darpotter Mon, 02/19/2007 - 00:40
Cant help with the IOS specifics... but a very easy test is to see whether IOS asks ACS for the ACL content.
If it does you'll see another authentication request with the ACL name as the username. If you dont you know its an IOS issue.
There was also a security hold fixed in DACLs sometime back where a requirement was added for the device to add a message-authenticator attribute. So if you see any complaints from ACS it could be that issue.
magurwara Thu, 03/01/2007 - 08:59
I am trying on PIX and failing. Get the following message:
"can't find authorization ACL". There is nothing in ACS suggesting that PIX asked for the ACL. However user authentication is successful.
Any ideas.....
magurwara Thu, 03/01/2007 - 09:13
Update.....
I do see in ACS logs that Authentication failed for ACL where username is the ACL name sent by PIX. (#ACSACL#-IP-myACL-45e6c605).
The failure code is "DACL request from device is not acceptable"
I guess ACS is rejecting the request, but WHY?
Vivek Santuka Sat, 03/03/2007 - 07:26
With ACS 4.x you need PIX 6.3.5 or 7.0.2+ for DACLs to work.
Vivek
darrengrey Thu, 03/22/2007 - 09:28
Hi - I am getting this exact same error message, I have recently upgraded from ACS V3.2 to ACS V4.0. I am getting this message from a (Cisco VPN 3000/ASA/PIX 7.x+)
Any ideas how to resolve this - it worked fine on V3.2 ?
ralfdechent Tue, 10/30/2007 - 07:25
I have configured DACL on a router c2821 with installed ios "adventerprisek9-m.12.4.4.T". The download from ACS to the router will work, but if the ACL on the Cisco ACS is modified, these changes will not properly move to the router.
Did you meanwhile fix your problem and can you give me a working config?
regars
Ralf
dkelemen1 Sat, 10/25/2008 - 08:05
Hi Ralf,
I am trying almost whole week how to force my router, with same IOS as Yours, to work with ACS and DACL but unsuccessfuly. I'm little confused, do I need aaa authorization filterserver command or not? Would You, please, send me your router config....
Darko,
regards
ariantow123 Thu, 01/29/2009 - 17:46
I got the same problem. Does anyone give some suggestion about other router, IOS, and ACS type/series that can do DACL ?
I tried c2691, c2691-advsecurityk9-mz.124-9.T5, and ACS 4.2 but it doesn't work.
