g.shdsl
Feb 17th, 2007
I have a project that they need one 2851 and fifteen 2801 and sixteen g.shdsl module.
I want to know how they will connectto each other and please let me know if there be a need for another device in this connection.
a.hajhamad Sat, 02/17/2007 - 22:44
These 16 sites will be connected to DSLAM or what? Also, put in your mind the backup connection if required.
I think you need to order a switches if you don't have for the LAN users in each site.
Another thing, i think there are two types of G.SHDSL modules either two or four wires, this is for bandwidth issues.
Please rate helpful posts!
Abd Alqader
nikolay-shopik Mon, 02/19/2007 - 13:01
You can connect each other via WIC-1SHDSL-V3 interface if you wish but in your case if there core site you better buy DSLAM with 16 G.SHDSL ports
