PEAP in AP1200
Feb 17th, 2007
I would like to use PEAP with ACS 4.0 , I follow a doc from Cisco but no luck.
* can any one help me how to deploy PEAP ?
* What is the different between PEAP & WEB ?
csannedhi Sat, 02/17/2007 - 17:03
Here is a document that I have used to setup PEAP http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00801df0e4.shtml
It worked for me.
Did you mean WEP when you said WEB? WEP is used for encryption as well as for authentication (if you are using Shared key authentication). Where as, PEAP is an authentication method, you can either use TKIP or AES for encryption to go along with it.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
