access point is not communicate with WCS
Feb 17th, 2007
Hi all,
This is saji,This is regading WCS probs which I am facing,I have project site which contains around 270 access point we are using the following device for the wirelss.
1.WISM
2.WCS
3.1240 AIRLAP lightweigt access point
all access point has been added to wism,but still I am not able to map some more access point to WCS MAP,I am attaching the snap shoot along with this conversation.WCS SNMP parameter has been config alredy and its working fine,WCS S/W version is 4.0.96.0 and WISM S/W version is also latest.The JPEG file shows the access point which in WCS,Its not showing with HOSTNAME.The same access point alreay ter in WISM with HOSTNAME and IP.any suggestion will be gr8 for me.
Regds
Saji k.s
Engineer-wireless solution
Overall Rating: 4 (1 ratings)
csannedhi Sun, 02/18/2007 - 18:08
I am guessing you have already added the "outdoor" map to the system. If not, do that first.
I am wondering if you had similar problems with any other maps.
Also after you select the APs and click on "OK" you will see all the APs cluttered at one corner. You may think it added only one AP to the map but behind it you will find the remaining.
troberts.isu Tue, 02/20/2007 - 09:32
This is fixed by following:
From the WCS:
Click on Configure:
Controllers
Click on the box next to the IP address to select all controllers.
On the top right of the screen select the SAVE CONFIG TO FLASH and click GO.
When this is complete the do the following:
On the top right of the screen select the:
REFRESH CONFIG FROM CONTROLLER and click GO.
This will update the WCS with the correct AP names and all other info.
Let me know if this does not work and I may have a few other things to try.
Tony
prakashj Wed, 02/21/2007 - 23:55
Hi tony,
Thankx for sharing the knowldge,It starts working fine..
Regds
Saji k.s
Engineer-Wireless Solution
Doha-Qatar
Trending Topics - Security & Network
