Cisco Bug ID CSCsh12711
Feb 17th, 2007
Where I can found the software version 7.2(2.4) for ASAs to fix the Cisco Bug ID CSCsh12711.
Went to "http://cisco.com/cgi-bin/tablebuild.pl/asa" and shows only 7.2.2.ED dated 22-NOV-2006. Is it the right one.
hoogen_82 Sun, 02/18/2007 - 05:54
No that is not the right one. If it says 7.2(2.4) it is usually fixed in 7.2(3). But since we do not have any such image we should look for interim images.
Check this image.
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/crypto/3DES/ciscosecure/asa/interim/asa722-10-k8.bin&app=Tablebuild&status=showC2A
It is 7.2.2.10 released on 12 Feb 2007
These images can be found on the same page just look for the Interim Images.
Hoogen
