CCSP Virtual lab
Feb 17th, 2007
I am taking my CCSP Exam. Can you recommend me any good virtual lab which is free or not to expensive.
Shyam
Hy Shyam,
Use the following:
- A PC with dynagen/dynamips (google for dynagen/dynamips)
- Built your own PIX (150$)(google for FrankenPIX)
- Use an external QUAD card to connect to a PIX or any other external device.
This way you will have virtual routers + a PIX and maybe other devices in 1 network for a cheap price...
#If you found this post usefull
#please don't forget to rate this
#Iwan Hoogendoorn
#CCIE#13084
whimpyred Thu, 03/08/2007 - 23:11
i use the services and information on firewall.cx
it's pretty good, as done the job thus far!
hope this helps
