Overlapping extensions with DDI's
Answered Question
Feb 17th, 2007
I have a problem where the DDI's coming into the company end in 90xx. This overlaps with outbound calls (90xx). Any ideas to get around this??
At the moment when you dial in on a DDI - the Call Manager then tries to dial out again!!!
Cheers
Dave
Correct Answer by Chris Deren about 9 years 7 months ago
Sure, make sure that the Calling Search Space applied to the Gateway does not have access to paritions applied to the route patterns, basically the CSS should only have access to parition applied to the phones, and perhaps anything else that is necessary.
HTH, please rate all posts!
Chris
Overall Rating: 4 (2 ratings)
Correct Answer
Chris Deren Sat, 02/17/2007 - 13:51
Chris
