Attendant Console Reports
Feb 17th, 2007
We are running Call Manager version 4.1(3)
My question is. Is there a way to run some sort of a report on when an attendant console user logs in/out of the attendant console application?
Robert
jbarcena Sun, 02/18/2007 - 10:59
Try using Performance Monitor, Stat --> Run and type perfmon.
Click on Action --> New Alert Setting. Click on Add, on the Performance Object select Cisco CallManager Attendant Console and then select the counters that you want.
//Jorge
