site-to-site VPN & Client on the same Router
Feb 17th, 2007
hello,
i'm running site-to-site VPN and VPN Client on the same router 3845.
The remote site of site-to-site has dynamic IP address through the ISP provider, I configure the VPN tunnel and the client config .
The site-to-site could establish the communication untill i remove the below line from the router config and put it back.
( crypto map to_dubai_map client authentication list sdm_vpn_xauth_ml_2)
The connection will remain up for some time then dropped again.
Or:
when i add no-xauth to peer as the below
crypto isakmp key XXXXXXX address 0.0.0.0 0.0.0.0 no-xauth
but when i add no-xauth the remote VPN client could not login or establish the connection.
Im attaching the config . Your help will be appreciated
Overall Rating: 5 (1 ratings)
Nicholas Poole Tue, 03/06/2007 - 09:28
Kanishka,
I had the same problem as the initial post and this fixed it for me!
thanks
