WDS Issue.
Feb 17th, 2007
How long does the client's credential keep in WDS AP?
and is there any method to not authentication through WDS AP?
I'd like to using only Radio Mangement for WDS without Fast Roaming.
Sometimes many client's authentication request make jamming by WDS AP's auth-cache
csannedhi Sun, 02/18/2007 - 16:07
I think you can not have only Radio Management without Fast Roaming when you enable WDS on the AP. Fast roaming is automatically enabled when WDS is used.
Cisco usually recommends one WDS AP per building. If you think the WDS AP is over-burdened, have you considered using WLSM to provide WDS? Response time will be much faster with WLSM compared to a regular Cisco AP. One more thing, the latest 1240 series APs have more processing power compared to old 1200 series APs.
