PIX FW Advanced - permissable for CCSP
Feb 17th, 2007
I am dong the CCSP course. I had completed the PIX FW Advanced course last yr. Does thsi exam qualify for the CCSP Exam or do I have to also undertake the PIX ASA?
Shyam
hoogen_82 Sat, 02/17/2007 - 22:42
The Best bet to check this out is to login into your Certification Tracking System and check your certification fullfilment requirement. I was just checking my own tracking system and it kind of looks like you might have to take the new exam.
Best thing to do is to log a case with
Certifications Online Support where people from Cisco would answer
http://ciscocert.custhelp.com/cgi-bin/ciscocert.cfg/php/enduser/std_alp.php
Log a case and check with them
Cheers
Hoogen
shyamatopsource Sat, 02/17/2007 - 23:54
Well I chedked in the cert tracking system and it gives a tick mark on the CCNA and CSPFA. So does that mean i have to give just 4 more exams.
I have logged a case with the Cisco guys as well..
Appreciate your response.
Shyam
hoogen_82 Sun, 02/18/2007 - 05:06
Well my guess would be since it is already marked you would require only 4 more exams. Thats good for you.
Cheers
Hoogen
