WLANS
Feb 18th, 2007
Hi all, if I have a wlan and I want to have different vlans within this, Do I just create vlans on my switches, and then does the wlan controller have ports I can plug into each of these vlans ? and If I wanted to route between them, would I just enabled ip routing on the switch ?
rduke Sun, 02/18/2007 - 08:42
Create your VLANs on your switch,
Create the same VLANs on your access points/bridges
Connect AP or bridge to switch in dot1q trunking mode - this will pass all VLANs between the two.
Use layer 3 switch to route between VLANs.
SSIDs map to VLANs, VLANs map to whatever security you need per SSID/VLAN.
Randy
carl_townshend Mon, 02/19/2007 - 02:28
Hi there, cheers for that, would I have to use a trunk link to my wlan controller also ?
