ICT with no Gatekeeper CAC
twissam
I am wondering if i need a gatekeeper in order to enable Call Admission Control between two Call Manager Cluster connected using ICT (those CcM belongs to the same company)
The SRND says no but any one has done it and can confirm it.
Good day
adignan
Level 8
Level 8
that is correct. a gatekeeper is not needed. The Location you apply to the ICT is what will control the CAC bandwidth for the incoming/outgoing calls between clusters.
please rate helpful posts.
adignan
Level 8
Level 8
