Frame Relay encapsulation
Feb 18th, 2007
Hello experts,
Playing around with Frame Relay, I noticed that setting an end to IETF encapsulation, while other end configured to CISCO encapsulation, won't do any harm: s
2691#sh frame- map
Serial1/0 (up): ip 172.16.0.1 dlci 301(0x12D,0x48D0), static,
broadcast,
CISCO, status defined, active
7206#sh frame-rel map
Serial3/0.101 (up): ip 172.16.0.1 dlci 102(0x66,0x1860), static,
IETF, status defined, active
Serial3/0.101 (up): ip 172.16.0.2 dlci 102(0x66,0x1860), static,
broadcast,
Serial3/0.101 (up): ip 172.16.0.3 dlci 103(0x67,0x1870), static,
broadcast,
7206#ping 172.16.0.3
Sending 5, 100-byte ICMP Echos to 172.16.0.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 116/148/188 ms
7206 can ping 2691, and vice versa is correct
Any explanation for this?
wpharaon Mon, 02/19/2007 - 00:36
After some debugging of Frame Relay packets, I found what exactly is going around.
Simply Cisco Routers understands both encapsulations whatever we configure; So setting encapsulation only influence outgoing packets not how to analyse incoming packets, (incoming type is irrelevant for Cisco routers).
Both configured to Cisco encapsulation:
04:14:12: Serial3/0(i): dlci 103(0x1871), pkt type 0x800, datagramsize 104
04:14:12: Serial3/0.101(o): dlci 103(0x1871), pkt type 0x800(IP), datagramsize 104
Local set to IETF encapsulation (outgoing packets), other end to Cisco, So local will receive Cisco encapsulated packets and sends packets using IETF encapsulation "NLPID"
04:15:11: Serial3/0(i): dlci 103(0x1871), NLPID 0x3CC(IP), datagramsize 104
04:15:11: Serial3/0.101(o): dlci 103(0x1871), pkt type 0x800(IP), datagramsize 104
On receiving router:
Serial1/0(i): dlci 301(0x48D1), pkt type 0x800, datagramsize 104
Serial1/0(o): dlci 301(0x48D1), NLPID 0x3CC(IP), datagramsize 104
gokula_chandran Mon, 02/19/2007 - 02:13
To add to these i agree that Cisco Routers understands both encapsulations whatever we configure;setting encapsulation only influence outgoing packets if its a non cisco device.
It depends on the remote device response, if its cisco it holds the same encapsulation otherwise it will take IETF.
