831 Router - Mulitple Static IP's to DMZ
Feb 18th, 2007
I have an 831 router that I would like to install in between our ISP and our network. Our ISP is providing multiple static IP's, which currently go to different servers, each with separate functionality, including 2 WWW servers with different content.
Can I user the 831 asa firewall device and a DMZ, point the different static IP's to different computers in the DMZ?
And if so, can someone point to some specific documentation or commands to perform the task?
Mark.
Jon Marshall Sun, 02/18/2007 - 13:57
Hi Mark
Yes you should be able to do this. You can create a DMZ on this router with one of the LAN ports. With the NAT your statements would look like
ip nat inside source static "local ip" "global ip"
Attached are links to 2 docs:
1) Setting up a DMZ on an 831
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a0080235e23.html
2) A document on configuring NAT and examples.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
Jon
