interface Virtual-Template11 VS interface multilink
Feb 18th, 2007
What is the difference between the interface virtual-template and interface multilink ?
where we can use each of them since i found some situation that we can use them interchangable?
B.R
Ahmadabuzayyad
spremkumar Sun, 02/18/2007 - 23:11
Hi Ahmad
Multilink interfaces are used to have a single logical interface bundle in which different physical interface will be a member.
We use multilink interface to get a single logical interface with high bandwidth capacity.
instead of having different physical link with less bandwidth capacities.
if its a simple point to point link between your locations and without any routing protocols better prefer multilink interface to have proper load sharing between the links..
for more info on Virtual templates you can refer the below link..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a008033a3bb.html
regds
