ASA and RSA SecureID
amisseri
We are currently using checkpoint and are moving to ASA5520. We also have a clientless SSL vPN appliance to roll into the ASA too.
My question is, how can I use the ASA for SSL VPN and IPSec VPN with RSA secureID? Can I do this for a select group of users, because most of the population do not have secureID tokens?
daviddtran
well, short answer is NO. You can not use
native SecurID in ASA as you would in checkpoint
because you can not store the sdconf.rec file on
the ASA as you would with Checkpoint.
The work around is to enable Native Radius
Server on the RSA Server and you still have
two-factor authentication.
That's how the old Pix 6.x works with RSA
SecurID
