Output errors and interface resets on the radio interfaces !!!
Feb 18th, 2007
Hi Netpros,
I have a situation where 5 APs which are managed by Cisco WLSE are showing some output errors and interface resets on its radio interfaces and this seems to be causing connection drop outs and also slow transfers. I am currently investigating the issue but would like your input as to what could be causing these errora and interface resets. As I mentioned teh WLSE does the radio management and so the power and channels is automatically adjusted by it.
Also any info about tools for troubleshooting this sort of issues will be great .. hopefully open source .. but it does not have to be .. I just will recommend to the customer if they can afford it :-)
Any input is very appreciated.
b.speltz Fri, 02/23/2007 - 06:39
Try to reboot the access points and see if it fixes the issue.Else try to Reset wLSE and reconfigure and see if it works.Also try for upgrading Firmware of APs.
Trending Topics - Security & Network
