Expanding Network
I am looking into making our (rather small) network more resiliant.
The attached files show the current network (CN.jpg) and the proposed network (PN.jpg). In the current network, the core switch is a CE500-12TC and the access switches are 3Com 4400-SEs with two CE500-24TTs.
I plan to implement 4 VLANs, for servers, printers, staff, and network management, so would want the distribution switches to be layer 3.
Firstly I am after any positive/negative comments about this design.
Secondly, what model of switch would you use for the core/distribution?
The access switches are being standardised as CE500-24TTs, except for the ones needing fiber connections with will be the 24-PC model.
Anthony
thomas.chen Fri, 02/23/2007 - 06:48
For the core and distribution layers, cisco recommends to use higher end switches like 6500 and 4500 switches because these swithces support L3 functionality with high processor and large memory.
scheikhnajib Fri, 02/23/2007 - 07:16
Mate,
I think that you network is too small to have 3 layers. You can consider a collapsed design where a single layer will function as core and distribution.
I would recommend a L3 switch in the collapsed core such as Catalyst 3650 or Catalyst 3750 ... A 4500 or 6500 will be very expensive for your implementation.
So 2 x 3650/3750 with standard multilayer image (you dont the enhanced image) and please get rid of the crap 3Com switches :-) ... an Express500 would be a good access switch for you or you can use the Catalyst 2960 instead.
Connect each of your access switches with two gig trunks to both core switches and interconnect both core switches with a multiple-gig ports and use EtherChannel. Configure HSRP on your core switches and you should have a nice running network after that.
Cheers.
S.
scheikhnajib Fri, 02/23/2007 - 08:22
Anthony,
If you are willing to pay for the 3750 then yes you can use the StackWise since it will offer you 32G, or I think it's 64G now, between both switches.
Sorry for not being clear but I yes I meant a single gig to each one of the core switches so total of 2 gig for each axs switch.
Cheers.
S.
Anthony,
Cheers.
S.
