WebVpn and URL entry
Answered Question
Feb 19th, 2007
I am using an ASA and WebVPn. It all works fine but on the left hand side of the WebVpn page. I can enter any url I like and get to that side, internal or external. Is there a way to remove this box where you enter a url.
Correct Answer by hoogen_82 about 9 years 7 months ago
Most probably you must have entered
asa(config-group-webvpn) functions url-entry file-access file-entry file-browsing
You need to no the url-entry to remove the url toolbar.
Hoogen
Overall Rating: 5 (2 ratings)
Correct Answer
hoogen_82 Mon, 02/19/2007 - 08:40
Hoogen
