CME DST
Feb 19th, 2007
Hi!
I was looking at the following DST document:
http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_tech_note09186a00807ca437.shtml
In particular I was looking for the update on Cisco Call Manager Express (with UNITY express , i.e. NM-CUE)
It says there that for the CME - it is "Under Investigation"
Any update on this? or does this mean we cannot do anything on the CME. Even the NM-CUE does not have a resolution, just a workaround.
Any help/comments would be appreciated.
thanks.
bing
irisrios Fri, 02/23/2007 - 12:36
Resolution:
Upgrade to newer version of software for the modules.
