Multiple VPN Client from 1 LAN
Answered Question
Feb 19th, 2007
we have 2 users who need to connect to our PIX 515 6.1(4) using Cisco VPN Client 4.0.5(Rel) client software over the Remote LAN Site.
they all have access to the Internet Via Watchguard Firebox and Cisco 1712 Router.
, but only one person can access to our VPN via the Cisco VPN client at a same time. when 2nd user try to log in, the other users connection will disconnect.
Does anyone have a same issue?
Correct Answer by acomiskey about 9 years 7 months ago
Do you have this command in your pix
isakmp nat-traversal
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Mon, 02/19/2007 - 08:35
kaisenmori Mon, 02/19/2007 - 09:13
Hi Acomiskey.
Thanks a lot for your reply.
Problem fixed.
Thanks.
