AAA Authorization help
Feb 19th, 2007
I have configured authentication for the outside users to connect to my servers using the following sample acl
access-list 110 permit tcp any host 10.10.10.3 eq http
access-list 110 permit tcp any host 10.10.10.4 eq http
access-list 110 permit tcp any host 10.10.10.5 eq http
aaa authentication match 110 outside TACACS+
Now for authorizing them do i have to create another set of acls or can i just use the existing acls and write
aaa authorization match 110 outside TACACS+
Is there anything else i should do on the AAA-Server for authorization?
Jason
Vivek Santuka Mon, 02/19/2007 - 09:04
Hi Jason,
You can use the same ACL for authorization. You will not have to do anything on ACS unless you need to push ACLs for the user.
Vivek
