Active Directory Group Policy over VPN 3030
Feb 19th, 2007
My company is finally getting around to implementing Active Directory. I can get a remote client to log in correctly to the AD Domain Controller through my 3030 Concentrator, however the Group Policies do not get distributed by the Domain Controller. Do I need to open up any ports on my firewall or select anything in the Concentrator to allow the policies trhough?
Overall Rating: 5 (1 ratings)
Kamal Malhotra Mon, 02/19/2007 - 09:57
If I understood correctly, then you want the group policies (parameters) to be pushed by the AD and not by the concentrator. In that case you need to create the group on the concentrator as 'External'. But in order to use it, you need the IAS service running on the AD server so that the protocol being used is RADIUS. On the AD, there is no option to configure the group policies.
HTH,
Please do rate if it helps.
Kamal
