A MAJOR SDM question
OK I've been WHACKED by this question on my 502 exam now 3 TIMES and I have no idea where to find the answer it's not in the official study guide, nor is it in the SDM slicks, or on the website.
The question is how many simultaneous routers can SDM handle? (configure, monitor) I would be s pleased if somebody would give the answer. Also cisco, why not actuallty write an exam with REAL qestions like how do you configure a VPN instead of stupid trick questiosn like this and the which SDM files HAVE to be presnt on the router.
bogdan.sass Mon, 02/19/2007 - 15:47
It depends on the phrasing of the question.
If it asks "how many routers can SDM configure", the answer is... any number (you can have SDM installed, and access and configure any number of routers with it).
If, however, it asks "how many routers can SDM configure simultaneously", the answer is "only one". You can only be connected to one router at a time.
